Part Identification: is this the C/C temp sensor?
I have my center console apart to do some wiring work with the stereo and body harnesses, and I found this weird looking thing that I assume is some kind of sensor. It's wrapped in gray foam padding. Inside is a tiny circuit board wrapped in black rubber, with the ends open to the air. It comes off the same wire loom as the Hazard Light switch wire plug and the Climate Control temperature/on/off ****. Is this the temp sensor for the Climate Control?
http://i887.photobucket.com/albums/a...0/DSCF1859.jpg
Hacc
01-06-09 12:40 AM
