Tire Stretching!
#62
where are you getting 225 tires stock? mine were 215, wide tires dont make the car handle or get traction suspension does. It has been proven by 10.5 pro outlaw drag racing class that you can make a car with 2000+ hp hook on a 10.5 wide tire, while in the old days people with that much hp had to tub the cars out and run 14" wide tires. My car handles just fine, as a matter of fact it handles better with my current tire set up then with my old supra tt wheel set up 235 up front and 275 in the rear. After all my car is not a race car, it handles good, and its slow the least i can do it make it look good while i'm at it.
Much of what you said in that post is completely illogical. Of course they had to run wider tires many years ago to get the same traction of a newer and narrower tire. Tread compounds are vastly improved. Saying that stretched tires handle better and that wider tires don't improve grip/traction... Stretched tires give a more positive response feeling at initial turn in but that's it. It may feel like an improvement, but overall grip diminishes.
On another note, I was only stating my opinion just like you were before. I don't understand something here that has become increasingly apparent on CL. Why is it that it's all fine and dandy when people want to express their opinion advocating modifications that are 100% proven to be detrimental to performance and safety (don't care what any non-engineer says about it being safe or done since the big-bang whatever it's BS and definitely less safe and if you knew how to prove it yourself then we wouldn't have these types of arguments), but when someone like myself expresses their own opinion without attacking anybody it becomes some sort of wrong doing? Why are the people advocating the truly correct way (not trying to bash on the aesthetic types who do these things for the looks and don't care about the obvious detriment) getting bashed for their opinions? It doesn't make sense. If your opinion is valid then so is ours. However, arguing with blatant lies is kind of ridiculous and is proving nothing good. Just accept that you can't have your cake and eat it too. There are always negatives. I've accepted that my car won't look as pretty as some of the others on CL because I want certain characteristics from my car that can't be had with that look. Acceptance is the first step to recovery my friend.
#63
For those who say tires have nothing to do with traction and the suspension does it all is like blaming your big brake kit for not stopping very well while running cheap tires.
Comparing traction of an outlaw 10.5 tire to street tires is, well, two different worlds. First off, full slick, different compounds, wrinkle walls, side wall and not too mention electronics such as traction control and boost by gear.
It's very true that a wide tire does not increase traction in a straight line, though it's not the suspension working witchcraft. Look closely at these outloaw 10.5's, tell me what you see in their tire set-ups. The sidewall, the taller side wall allows the tire to wrinkle. Wrinkling increases the threshold before breaking loose; therefore, allowing the tire to "hook" more power. Suspension is a key part of weight transfer and putting the power down to the ground but to say tires don't have much of a role in traction is wrong. It's a healthy balance between suspension set-up and tire set-up. Throw a set of equally sized street tires on one of these outlaw 10.5 cars and see what happens.
#64
You and him have something in common, you both argue till youre blue and talk smack about other things you know nothing about.
1. You argue about supra...and never driven or even rode in one.
2. Hes arguing about tire stretching from reading about it on the interwebs and owning a stock sc300, which handles like a old boat on stock sunken 16" wheels that are more narrow then 8.5"
and who said anything about extreme stretch? 215 on 8.5 its not even a stretch, i didnt have to use an air cheater or lighter fluid to get the bead to sit on the front...how is that extreme if anything its a baby stretch.
For the record, I bought my Lexus with the intent on keeping it stock (with the exception of a few electronics such as HID's and radar detector) because I enjoy the quiet, smooth, comfortable ride, and reliability. I did not buy it to hammer around corners, I have a GSXR for speed. I've had all kinds of sports cars, including an M3 (racing dynamics stage 2), so, yes I know how a car can handle. If I was going to buy a car to build for handling it would start with something ligher, and with better weight distribution. Trust me, I do enjoy my 16" wheel and tire ride, quite a bit....
#65
jesus christ so much butt hurt in this thread. if you want to stretch, stretch it, but get it done by an experienced person and check for bubbles, cracks, etc often to reduce chances of getting f-ed up. and please don't try to justify it by saying you're doing it for performance b/c the only performance most people get from stretching tires is a stiffer sidewall, which might be better in a very limited range of cases.
if you don't like stretch, then just don't stretch it. w/ all the fanboi-ism that's around, I think most people know the pro's and con's of stretching tires by now.
different people have different tastes, why the hell can't people just accept that.
and btw, the cyberevo doesn't exactly run meaty tires
and no, they didn't do that to impress the hella bicycle people in norcal. obviously, this is a track car and i'm sure 90% of people who stretch tires don't do it for the geometry that the people who setup the cyberevo were after. jus' sayin'...
#66
^, Agreed. I do not tell people what to do, I only suggest when asked. It's an individual's car and they can choose to do whatever they want to their cars however they want. Justifying it as a performance advantage is another level. Everyone's knowledge about cars differ. The best we can do is to steer the newer generation in the right direction.
I knew someone was going to post a picture of the Cyber Evo. I one-up you with this.
#67
This is funny! If you have to stretch your tires at all you purchased a wheel with the wrong offset. I had 18x10 with a 285 on my 240 with a very slight roll in the rear. I just disagree with the whole idea of tire stretching. All it takes is a bit of planning and some measuring and you have a wheel that fits perfect without a stretched tire. You can fit a 305-315 in the rear of an sc with very little work. ...but to eachs own buy a 10" wide wheel and stretch a 195 on it. Its your car do what you like
#69
do what you wish but dont tell people its wrong, some people like this look( and alot of people do) and so people dont. Its your car do what you wish, at least we are not putting 24" rims on our SCs and putting 5" lift kits on them.
#70
Wait, hold up a second, the drag racer in me is about to come out...
Have any of you actually looked at a 10.5W tire in person?
And are you aware most outlaw 10.5 guys are running 12-16" wide wheels on those tires?
#72
The "Drag Racer" in you should know that this is greatly due to the fact that the sidewall in Slicks compress greatly, they bow out when doing so, and you DON'T want that close to your fender's when you're pulling a 9 second 1/4 mi. They are allowed to still compress while being stretched because, well, there's a difference between the 40 series tires you're stretching, and the pofile of Drag Radials. What's next? Bringing Mud Tires into the mix?
I heard someone say "at least we're not putting 5in lift's and 24's" dude.... I hate that as much as the next person, maybe more. But I think you just hit the record for hypocrisy. They put lift kits and rim sizes that were never intended for this car with adverse effects to ride, handling, braking and acceleration and look ridiculous to you, you put drop kits and rim sizes that were never intended for this car with adverse effects to ride, handling, braking and acceleration and probably look ridiculous to them.... Yet you have the nerve to talk about not telling people what they should or shouldn't do to their car, or what mods are and aren't wrong, and a general "to each his own" type of statement when following with the exact same type of statement.....
For the record I hate 24's and lift kits on cars....so don't think I'm defending them, but I also hate blatant hypocrisy and general ignorance.
#73
Wait, hold up a second, the logical side of you should come out..... There is a MASSIVE difference between street tires and drag slicks.
#74
#75
Sounds like a nice F-body, I've seen built/Hosed LSx F-body's dead hook on the street with less tire than that up in Chicago and Michigan. You'll get no argument from me about proper suspension geometry and lift points, I've setup quite a few. Mostly Tube frame/4-link cars though.
It took you 2 paragraphs to explain to me...what I've known for 20 years. In both of those lengthy paragraphs, you still didn't answer my questions that were aimed at the people bringing 10.5W tires into the conversation. You sir, are providing me good entertainment today.
My plans for the SC are very simple, good looking car with a little bit of HP, na-t with about 400rwhp. I know that no SC will hook with any tire with 400rwhp in 1st or even 2nd no matter what size z rated regular tire youre using. You can run 325s or 245 and you will spin just as much. Run a Dr and then you can hook, which i dont intend on doing. My plans are just to be a reliable cruiser that i can play around on the highway with. I'm just drained from strip set ups and working 100+ hours a week on a car that can go down the track a few times.
