SC- 1st Gen (1992-2000)
First attempt DIY headlight cleanup - FAIL
Old 05-05-11, 10:17 AM
8600RPM
8600RPM's Avatar
I take it the lower heat worked?
When I first read the DIY on this forum and it said something along the lines of 350 degrees for 3 minutes I almost spit out a mouthful of water, that seems a bit extreme for me.
I've done this several times (never on an SC though) and we always used the ovens lowest setting for about 5-7 minutes, with the lens on a wet rag. Seems to heat up the sealant more evenly.
Looks good though all cleaned up!
Old 05-05-11, 11:28 AM
booga
booga's Avatar
I had the oven temp at 250, but I know that y oven operates at lower temps from what I have experienced cooking a turkey for more hours than normal. I did see another thread recommending 350.
Good advise on the wet rag. I was worried about the metal touching the plastic, so I did put it on top of damp cardboard.
Old 05-05-11, 12:31 PM
SC_coupe
SC_coupe's Avatar
I took the easy way out and have been enjoying condensation-free headlamps for the better part of a month now. I recommend doing this after you reseal to stop it from coming back...
https://www.clublexus.com/forums/sc-...headlamps.html
Old 05-05-11, 03:52 PM
booga
booga's Avatar
That's the thread I was referring to. I had to open it up because the condensation was not going away. Now that it is clean inside, I am going to double up on it by doing this fix.
Thank you.
littleyan9
01-08-20 03:54 PM
xtremex626
10-16-11 01:38 AM
qewani1
05-08-09 08:56 AM
Quick Reply: First attempt DIY headlight cleanup - FAIL
