I tired 18x8.75 +20.... I failed
http://www.supraforums.com/forum/sho...pension-thread
i am lower than stock, probably ~1" if i had to guess.
美少女戦士セーラームーン
+1 Hil.
Right now you are seeing positive camber due to suspension geometry. Once the suspension is loaded back on the ground, natural camber will take its place to bring the wheel in a bit.
After some calculation, you'll need a mild stretch to fit depending on your drop and tire choice.
Is it just me or am I starting to see more and more of the these odd widths now? Haven't seen very many x.75" wheels until the past couple of weeks.
i have the gixxer_drew suspension setup
i am lower than stock, but nothing insane.
You won't be able to tell until you put a tire on it and drop it down
Im running the same width rim in the front with the same offset on 19" wheels and it looks perfect. I didnt even have to run a stretched tire to do it. I did do a little rolling but nothing drastic at all. It only rubs a little when I hit a bump at higher speeds or turn very sharply (i.e. getting out of my driveway) etc.
I am lowered 1.5" in the front on some Espilir's FWIW.
Good Luck with the fitment- post some pic's when she's done
edit: what size tires are you running too?
I'm going to ask an obvious question: has your car ever been wrecked in the front ? If so things may be a little out of whack and you can only tell with close clearances. Also, how is your front alignment ? Worn bushings could cause the wheel to be a little out of spec.
