Possible Bad Cluster?
On my 94' SC400 I notice in the cluster only some of the gauges work. Only the temperature, gas, and sometimes RPM meter. The speedometer & odometer completely stop working. And the RPM meter seems to work randomly when it wants. Could it be a bad cluster or fuse? Let me know what you guys think or recommend. Thanks
The lights are on perfectly on the entire cluster. It just the speedometer needle doesnt move at all when I drive so I dont know how fast im going. And the RPM works sometimes. Other times it doesnt move at all like the speed needle.
I don't know if you can find them from the dealer anymore but you can chase the down from some of the used parts dealers on here like Aliga. Usually what goes bad is the capacitors on the little driver/motor. If you know a decent small electronics shop that will replace the capacitors for you that usually solves the problem. My speedo does this about once a week so I've done some research for when it becomes a bigger problem.
SC_Edgar
SC- 1st Gen (1992-2000)
06-28-18 11:40 AM
