broken lug nut
when I got a flat tire last year I couldn't find my wheel lock key anywhere, stranded on the side of the road I found a socket that just barely fit and hammered that b*tch on and used a breaker bar to take it off. I've also used the snap on bolt extractor which works really well
after getting the rim off. i used one of the factory lug nuts to pull the broken stud forward. when i go to turn the wheel forward it doesn't scrap going backwards is a whole mess like metal on metal. nothing is bent but trying to break the caliber bolts loose after soaking in pb blaster aint going no where even with a impact gun.
it doesn't seem to be hitting anywhere so what else could be causing the rubbing noise ?
didn't replace it yet. i used a 400lb impact to pull the old one forward. none of the parts store had a stud in stock ill get one tomorrow. guess that wasn't enough cause it sounds bad when i reverse
front passenger side. only make it noise in reverse didn't see anything hanging or bent im gonna look into it deeper tomorrow it drives fine makes a lil noise till i speed up then it stops.
