SC- 1st Gen (1992-2000)
Auto to Manual ECU needed?
Old 05-12-11, 05:56 PM
yell0w
yell0w's Avatar
Default Auto to Manual ECU needed?
I'm in the middle of getting my 97sc300 swapped over from auto to manul. Using a 95sc300 w58 tranny.
I've searched and found that a lot of people who've done the swap has just kept there auto ecu to operate the vehicle. By doing this the ecu will throw a CEL.
What are the best options to do about this?
a) just use the auto ecu and live with the CEL
b) buy which type of manual to fix this(any year sc300 manual ecu would work?)?
c) other?
Old 05-12-11, 06:59 PM
88supramki
88supramki's Avatar
I believe you can use either one with a manual, however using the manual ecu will be better in the long run.
The Auto ECU has the electronic control for the AT, which obviously isn't needed for the MT. There might be a few other things, but I haven't looked into them that deep.
What do you mean by, "Buy which type of manual to fix this?"
Old 05-12-11, 07:01 PM
yell0w
yell0w's Avatar
I meant does it matter which type of manual ecu i get? Pretty much can I just go to the junk yard and pick up a 93 or whatever year manual sc300 ecu and put it in my 97sc300 and it would still work. Sorry for the confusion. But I do appreciate your help and if you can help even more!
Old 05-12-11, 07:10 PM
MidloSC
MidloSC's Avatar
No. 92 to 96 are OBDI, and 96 to 2000 are OBDII. The problem is you won't find a manual ecu in anything newer that a 97. My suggestion would look for a rebuilt or used 97 manual ecu.
Old 05-12-11, 07:11 PM
Toshima
Toshima's Avatar
I dont no if its the same but when i swap my 240sx to a 5 speed I never got a cel. It was obd1 though.
Old 05-12-11, 07:17 PM
abounly
abounly's Avatar
OBDII are stingy, if you want it to run without CEL you gotta find a 97 manual ECU which is extremely rare. What people do for the CEL they run resistors and they plug in the sensors from the auto.
Old 05-12-11, 07:44 PM
yell0w
yell0w's Avatar
i appreciate all the input guys!
If i just kept the auto ecu. Will i notice anything different besides the CEL?
Old 05-12-11, 07:49 PM
abounly
abounly's Avatar
Gearing is different so you will be at a higher RPM i believe.
Old 05-12-11, 10:03 PM
good2go
good2go's Avatar
Here's some related info for you (advanced search is your friend):
https://www.clublexus.com/forums/per...ght-issue.html
https://www.clublexus.com/forums/per...ml#post6342552
https://www.clublexus.com/forums/per...up-lights.html
Note: these may not be in chronological order.
BTW, honorable mention goes to cartmill for pioneering a lot of this stuff
Old 05-13-11, 12:00 PM
1jzgte603
1jzgte603's Avatar
I have a 2jz 5 speed ecu if u want to trade i for ur auto ecu and automatic tranmission computer.. or atleast let me buy your auto computer for the trans??p.m if needed
Old 05-13-11, 10:12 PM
yell0w
yell0w's Avatar
I've actually ran across these a few times and I have contacted cartmill as well. But from what I remember these were meant for the vvti sc300 which my 97 doesn't have.
Old 05-13-11, 10:13 PM
yell0w
yell0w's Avatar
I only need it if it's a 97 manual ecu.
Old 05-14-11, 07:14 AM
good2go
good2go's Avatar
Regardless of the year, I figured it was directly related from the standpoint of tricking the auto ecu to work with a manual.
Old 05-14-11, 07:38 AM
1slowsc
1slowsc's Avatar
I have a 1993 manual sc300 and replaced my ecu with an auto. I now have a cel on and another thing about it is that when u fullthrottle say in second gear, it will pause for a second and then go like it were to let off gas to downshift. Most the time it will do that anytime u fullthrottle. Other than that it drives the same.
Old 05-14-11, 08:50 AM
yell0w
yell0w's Avatar
Correct! I figured the vvti would be completely different...not to sure. I guess that's why this thread is up. hahah.
I do appreciate all the help!
Quick Reply: Auto to Manual ECU needed?
