LED turn signals
I installed LED turn signals. (REAR, FRONT, SIDE INDICATOR) and with only 2 lights in, they flash fast. With 3 in, they just stay on and make a buzzing noise.
How can I make it so that the signals flash the right speed? Do you have to wire in a resistor?
If our cars have an exact match for the limited available "electronic LED flashers" then we can change to that(which is actually a cheaper way to do it) but if our cars don't, then you're gonna need to wire a load resistor for each bulb you're replacing with LED that don't flash right.
Hey, I just found this at superbrightleds.com, http://www.superbrightleds.com/cgi-b...CF13GL-02.html, it kinda looks like my '95 SC400's flasher relay, I will try it, if it works I will let you know. I'm just not sure if we have the same kind of flasher relay. Here's some pics of my stock flasher so you can compare;
kenaston99
07-13-18 07:56 PM
imherenow
03-28-12 05:11 PM
