SC300/400 Tail Lights Lens Interchangable?
Hey guys just wondering if the any SC300/400 year Tail lights are interchangable because i was looking for an SC with a pass tail light and wanted to switch the lens with my 97's thank you for your time.
Yes, they consist of three pieces
1) Backing - depending on the year this will determine which bulbs you use. and how the bulbs will socket in
2) The Core - This will give you a different color color setup according to the bulb layout, 95s can be modded to match a 97 setup
3) Outer lens - the outside color setup
ScottURNot's DiY: https://www.clublexus.com/forums/sc-...iy-thread.html
A similar turnout with craftsman in the plexi glass: https://www.clublexus.com/forums/sc-...il-lights.html
Overall discussion of various tails I've even posted a video. read up though on scotts though if you have newer tails the temperature will be different.
https://www.clublexus.com/forums/sc-...post-pics.html
Now, I know the eBay lens don't fit 100% proper, but with work and some custom cutting I believe you can make them fit like another member did with the clear headlight lens. I'm sure you could get that done with the help of your friends and have a grinder somewhere in that garage.
Guest
Posts: n/a
