how do you replace the driver seat belt on a sc300?
Hey guys I just got a replacement seat belt for my drivers side. I was just wondering if I can pop out the panel or are there screw anywhere to take off first? Thanks!
You'll have to remove the upper window surround first (just clips holding it in I believe) and then you'll see the screws along the bottom of the window to undo the lower panel. The bottom are push in tabs which can be accessed after removing the rear seat.
i have been pulling out my rear interior a bit lately and it goes like this. pull the seat bootom then the seat back. then take off the lower panel first its just push pins then the upper panel bolts in the ohish bar. and there is your seatbelt mount. straight forward.
