Whos single turbo??
im now running a single turbo i kno there are two oil feed line and return lines.
what do i do with the two i wont be useing how do i reroute of fix the extra two lines
^^what he said, but the oil drain flange on the engine has two inlets i took it to a shop and had them cut the other one off and weld it shut. and plugged the oil feed line on the back of the motor with a bolt, but i will be re-opening it for my oil pressure gauge to tap into it.
this is what you do:
http://store.driftmotion.com/static/...ingleturbo.php
buy that^
it comes with everything you need. fittings for the feed/return on the turbo and for the block. it also has the cap for the one feed line
buy that^
