fan not blowing
Re: fan not blowing
Originally posted by lionj
My fan is not blowing when I try to use the a/c. could someone tell me the problem?
the fuse you should look for is @ your driver's side kick panel, second row down and second from the end.
Row 1: Fuse Fuse Fuse Fuse Fuse Fuse (you get the idea)
Row 2: Fuse Fuse Fuse Fuse Fuse Fuse (The fuse you want) Fuse
The end of the row is the side that's closer to the firewall.
Did I explain it well enough?
If not, check your manual -- it lists the location of all your fuses.
John
