Code 62-Shift solenoid, but they check ok
Pulled em out, 15 ohms, 12 v makes em operate, can blow thru them until energized- or vice versa, I forget. So, next is ECM-which is gonna be cheaper than solenoids. Funny, Lexus manual says 5 ohms, but Supra manual says 15 ohms. Misprint? The code gets thrown if less than 8 or more than 100, so I'm thinking 15 is the right number.
I put them back in hoping it was a bad connection, also cleaned the ground wire, but still throws code 62. Anyone seen this before, and did a rebuilt ecm fix it? I've read the ecms are pretty reliable.......
My manual says solenoid resistance should be 10-16 ohms. Code 62 looks to be for solenoid #1.
-bug
