Repair: Door Panel Clips
call you toyota dealer and ask for the part. Need to know left or right.
Part #s and other useful help are here:
https://www.clublexus.com/forums/sc-...iy-w-pics.html
-bug
-bug
So those are the 3 ORANGE "RETAINERS"
These are the ones that go behind the carpet they are long about 40mm and will have to be ordered from a dealer, them being closed on sunday I will find out if I can get them
67771-12050
These are the 3 RED "RETAINERS"
These are the ones that will go near the END of the door. These are small and are not interchangable with the ones above due to the size.
pics in a few
These are the ones that are interchangeable with other toyota models
67771-12050
pics in a few
i call them push pins. and most of mine are trashed from pulling the panels off too much. i replaced a few last time i was at pick a part. stick em in your pocket=free. i was curious about this thread because here is my problem suggestions please.
after taking off my door panels so many times then putting them back on some of the holes that hold the pushpins have cracked and wont hold the pins right anymore. the plan is to glass the whole fiberboard piece of the panel and try to reshape the holes back to normal. is there any other way to fix it? if i cant get that to work i will be looking for new panels. thanks.
I actually just went to home depot and bought Industrial Glue. If you look up OLT's thread he shows you how to solve the cracks. I took that to a whole new extreme by gluing the cardboard type stuff and just pretty much glued EVERYTHING, Dont know what the side affects are gonna be but it sure is alot sturdier.
mick_foley
02-05-08 08:18 AM
