SC- 1st Gen (1992-2000)
Removal of Stock Sub sc300
Old 09-10-02, 07:42 PM
tommym
tommym's Avatar
Default Removal of Stock Sub sc300
I just put a 12 in the trunk and want to take out the stock 10 in the rear deck, in order to make a pathway for the sound to travel into the cab of the car. how the hell do I get that sub out...i got the cover off...do i ahve to take out the seats? Let me know
Old 09-10-02, 10:49 PM
Lex Luthor
Lex Luthor's Avatar
Do a search, you'll find very specific instructions
Old 09-11-02, 03:56 AM
henrynguyen
henrynguyen's Avatar
Thumbs up Not too hard
Well on my 93 sc400, I took off the whole cover. There are two black plug screws located at the center of each back seat. Pull them out first. Then the seat belt cover for the left and right(becareful with this part, it break very easy). Take off the sub cover(very easy, you might be able to take the sub out too). Next pop off one side first, and reach your hand under the cover and try to pop them up until you reach the center. Then pop the remain side.
Good Luck,
Old 09-15-02, 10:46 PM
lexus baller
lexus baller's Avatar
just get a door panel remover and popped the top grill out , it's all clips. then you remove the sub with 4 10 millimeter nuts that holds the whole bracket in. If you really want sound to travel through, remove your back seat and there's a big oval plate that covers the gas tank, remove that and put your back seats back and you'll get bass from hell.
Old 02-11-07, 11:21 PM
ZSC3
ZSC3's Avatar
been here.. done it... awesome results, my solobarics slap so much harder from these 2 easy diy's...
Old 11-28-07, 06:23 AM
labtec
labtec's Avatar
is removing that plate safe!! it's probably there for a reason...safety maybe
Old 11-28-07, 06:49 AM
KrazeMatik
KrazeMatik's Avatar
i have problem taking my out also the only prob i had was actully taking out the sub i already took out the cover and all screw but my seem to be stuck to the car like some kind of black foam....
Old 11-28-07, 10:35 AM
Baoser
Baoser's Avatar
the foam is just double sided tape foam, pull and it should come right off
Old 11-28-07, 01:22 PM
IS_Sunny
IS_Sunny's Avatar
WOW ... a bump of one of my first posts ever. 2002... damn I was a nub.
What kinda thread was this LOL.
Old 11-28-07, 05:20 PM
KrazeMatik
KrazeMatik's Avatar
is this the reason why i cant get my speaker oout is there more screws? btw i have a sc400
Old 09-22-12, 12:37 PM
ocratitude
ocratitude's Avatar
Default making more bass
I was wondering if anyone has any tips on removing the oval plat under the back seat and if anyone has pictures or a link to a thread that has pictures on how to remove the stock sub woofer it would be greatly appreciated.
Hagar
07-01-20 08:38 PM
KgBoostnGS
GS - 1st Gen (1993-1997)
01-15-12 04:43 PM
ychachad
02-03-09 02:06 PM
Justakid
01-14-07 01:43 PM
Quick Reply: Removal of Stock Sub sc300
