Turbo Exhaust (Downpipe) Question
Where do you buy or what does everyone use for cuctom 3" downpipes to connect to dual 3" pipes for rear? Do exhaust shops cutom make a Y connection or does someone sell this?
Thanks,
Robert
Thanks,
Robert
Exhaust flow at transitions is important. If your transition induces turbulence your turbo response and power will suffer. I recommend a PROPER "Y" pipe be used and one of the very few places that does it correctly is Burns Stainless. http://www.burnsstainless.com/
The Y is available in parallel or splayed. 3" in mild steel is $135 and in 304 stainless it is $162. Go here: http://www.burnsstainless.com/MergeC...into1base.html
For the best configuration add $60 and have Burns build you a real scavenging Y-pipe based on your engines requirements. Go here: http://www.burnsstainless.com/Crosso...rossovers.html
Can you buy a cheaper part? Yes. Will it make as much power or last as long? No.
I'm still trying to decide whether to go 3" or 2.5" duals to mufflers. I see that Supra owners only have single 3". I would hate to put 3" duals and lose power.
