SC- 1st Gen (1992-2000)
Stocks Sub swap?
Old 07-03-11, 06:43 AM
  #31
bleedspeed
bleedspeed's Avatar
Originally Posted by P.R.S.22
I've got a Pioneer 10" sub in the stock location. Gives me just enough thump I need. Had to put a piece of wood in the stock sub location to raise the aftermarket sub enough to be flush. You can't see the wood because it is covered in the black speaker trim which gives it all a complete stock look. No complaints whatsoever on the change.
looks good man! but not stock with no grill. take a look at my thread to see how i made a grill for mine. it takes a 12"grill.
Old 07-03-11, 09:16 AM
  #32
socal72
socal72's Avatar
Originally Posted by GS FONZy
wattage means nothing until you say the brand of amp you are running. Now-a-days there are cheap @$$ amp that are way over rated inorder to sound and look appealing to consumers, but when it comes down to it, they aren't worth a $h!t
So when you go amp shopping, keep this in mind. Decent amps run about $1-1w at 4ohms.
Sorry about that, I should of told you what I had. Right now I have a Alpine PDX-F4 and Alpine PDX-M12 I also have a Rockford Fosgate Power T400-4 and Rocford Fosgate T1000 "2009 Edition" along with Two sets of Alpine Type-R's 10's/12's and Type-R 6.50's for the front and rear. Oh yeah and for you "old school peeps" I have a Audiobahn A2200HC amp. So hows that for "Brands and Wattage"?
Old 07-03-11, 09:31 AM
  #33
SC51
SC51's Avatar
socal72
Couldn't agree more, amen
Old 07-03-11, 11:11 AM
  #34
Durrby
Durrby's Avatar
Originally Posted by socal72
Hey Durrby, How much trunk rattle do you have with the subs firing up at the trunk lid? With it being all sound deadened does it stay pretty solid?
Not a lot of rattle but it does flex a little. The lid itself hasn't been dynamatted though, just the fender area, inside the tail light housing, behind the license plate and the whole doors. There's little to no rattle inside from the subs when cranked up and is crystal clear even at 3/4 volume.
https://www.clublexus.com/forums/sc-...reo-build.html
Old 07-03-11, 03:49 PM
  #35
socal72
socal72's Avatar
OK thanks for the info , but just to be sure I think I will Dynamatt the lid too...
Old 07-03-11, 08:59 PM
  #36
P.R.S.22
P.R.S.22's Avatar
Thanks bleedspeed I thought the thread was about putting an aftermarket sub in the stock location. Whether I retained the OEM grill or not was optional. Its all good though....I'm ok with the sub being exposed the way it is. Its still a somewhat dark color so it blends in well with the black felt wrap for me.
Old 07-03-11, 10:19 PM
  #37
bleedspeed
bleedspeed's Avatar
yes stock sub replaced and round grill added.
Old 07-03-11, 10:25 PM
  #38
P.R.S.22
P.R.S.22's Avatar
Ahhh...gotcha. In the future I may go with your advice and go with a larger round grill to put over the sub in order to retain the full stock look. Only time will tell.
Tank
11-21-16 07:28 AM
kayrohit12
04-11-13 09:56 AM
fordsvtmfl
03-09-09 08:13 AM
yolnerd
02-14-08 12:55 PM
Quick Reply: Stocks Sub swap?
