Finally Got My Transmission Done!!!!
So i finally got my transmission in and took her for a ride for about a 1/2hour just riding around. Not sure if its me but it doesnt pick up as fast as it did with the sc tranny. btw. i have a ls400 tranny,which should be that same transmission.
as far as i remember.. one has a has a taller first gear.
Correct me if im wrong but that means you didnt get the exact same transmission![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
ie:
92 sc400 transmission part#
35000-24280
92 LS400 transmission part numbers#
35000-50013
35000-50040 CALIFORNIA SPEC (08/1992 - 12/1993)
35000-50070 (08/1992 - 09/1994)
there are differences.. im just not sure 110% what they all are
Edit:
Searched and what i can find is :different valve bodies, torque converter, 1st gear ratio.
the LS400 came with a 341e, a340e and even a 5spd a650e
so depending on which one you got installed now, you could have a few different things going on
ie:
35000-24280
35000-50013
Edit:
found this from a couple years ago. pretty much confirms the different gear ratio theory
http://www.lextreme.com/forums/archi...p/t-11448.html
Thank for the good info. Wish i would have gotten this info before i did the swap. I have made up my mind to do a 1jz 5speed swap. Just tring to get my $ right.
waynesford
109
07-08-20 09:20 PM
PerpLexusd
12-15-13 07:50 AM
