Fog Light Question
Tried searching for it but there was too much to go through. Going to be getting a body kit on my 95 sc400, and was wondering if i needed anything other than 97+ fog lights?
so i have a 93 sc300, with the 97 front conversion.. in order to install the oem fog lights what is all needed? im picking up fog's from a member on here and i was just wondering if there's any extra accessories that is needed?
you could make your own switch or do what i did and set it as a day time running lights. If you make your own switch, make sure you use a relay with the right wattage for the lights you are going to use if for. if you are using H3 bulbs, your local auto parts store should have a relay good enough for your application. I used my radio as the switch. I hooked it up to the remote wire from my head unit to my amp so when they turn on when i turn on my car. Works pretty good. I used my head unit cause I didn't want to have to drill any holes in my dash.
