STEERING Wheel removal (help please)
How do i remove my steering wheel from a 92 SC to install a NR-G hub and quick release? Any help or DIY guide would mean a lot. Thank you for your time CL family
SoarerGold,
I found this thread that just completed what you are trying to do, while it is not a DIY tutorial, it does tell you what screws to pull, and what you may run into, check it out, and see if that helps you out.
https://www.clublexus.com/forums/sc-...ing-wheel.html
yep, the planet soarer one is good. I recently changed mine for a three spoke wheel. Sometimes the wheel hub is really on there. I actually bent the two steering wheel bolts from the kit that I rented from autozone so I couldn't return them. Just keep in mind that you no longer have an airbag and your airbag light will be on now. Most places won't pass a safety inspection on vehicle with an air bag light. Best of luck and take photos when you're done.
Keep in mind Tabaka that a lot of other states don't require safety inspections haha. And you can also buy a resistor that will stop your airbag light from coming on.
I'm actually about to switch back to a wheel with an airbag, head-on collision at 45mph for both cars and I'm still alive because of an airbag. Just keep that in mind.
Evoaz92
12-24-19 12:20 PM
