clock stays at 3:15
clock stays at 3:15
1995 sc300 5 speed
Everything works even temp display but the clock wiil not advance past 3:15 I try to set and it just dims when trying to set it??any clues ???this is the second sc that did this my first was a sc400..
Hey guys, thanks for the cheer i needed that lol. but ive searched nobody has had this problem at all ??? Im confused because this is my second 1 that has had this problem...checked the fsm it seems that the clock is on a board that can be changed out!!! has no one swap that circuit board yet???
Are you saying that you can set it, but it just doesn't keep time? Or, does it lose time every time you get into the car?
Could it be that the "H" or "M" or "00" buttons have a little gunk in there that is not letting them release properly making the clock think that you are still setting it? It is like when you pull the crown out from your watch to adjust the time. If you don't push it back in then the watch does not run. Just something for you to chew on.
Give us a little bit more information on the issue if that doesn't fix it.
