key fob reprogram?
Recently, I lost my master key, but couple days ago, I found it! For this event not to happen again, I wanna get another spare master key. If I get a used key fob from ebay, can it be reprogram?
Can anyone show me the steps to reprogram the key fob?
Look for 98+ SC instruction only!
Information courtesy of CL member farkus. I used this to program a replacement master key for my 1998 SC300. Original post can be found here: (post #8) https://www.clublexus.com/forums/gs-...mming-key.html
This is a two Phase program.... The door functions(Which I think you already got to work) and the computer to start the car.
Lexus Key and Remote Programming
Key Programming 1. Insert an already programmed master key into the ignition. Do not turn.
2. Press and release the gas pedal 5 times.
3. Press and release the brake pedal 6 times.
4. Remove the key from the ignition.
5. Insert the new key you want to program into the ignition.
6. Press and release the gas pedal one time.
7. Wait 1 minute. The security light will be blinking for this one minute. When it stops blinking your key is programmed. To end programming step on brake one time.(Sometimes it takes LONGER than 1 minute,Wait it out)
NOTE: Look for your security light. This light will guide you during the programming procedure. The security light will go off at Step 1. It will remain off until Step 6. The security light will come on and start to blink after Step 6 until the key is programmed. If the security light comes on after Step 4 STOP the procedure and start over again.
If you perform this procedure too slowly your car will not go into programming mode. If you can not get your car to go into programming mode make sure you are using a master key and not a valet key. If you have a master key then you will probably need to perform this procedure more quickly.
Remote Programming 1. Close and lock all doors. Unlock and open drivers door.
2. Put key into ignition and remove. Do not turn it on.
3. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock)
4. Close and open drivers door.
5. Using the electric lock switch. Lock and unlock 5 times. (Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock, Lock, Unlock)
6. Put key into ignition. Turn to "ON" , turn off and remove.
7. You will see the door locks cycle by themselves.
If the door locks do not cycle (lock and unlock) by themselves then the car isn’t in programming mode and you must start over.
8. On the remote, press and hold the LOCK and the UNLOCK button at the same time for no more than 2 seconds.
9. On the remote, press the LOCK button for no more than 1 second.
AT THIS POINT, the locks should cycle by themselves ONE time. This means the procedure was accepted.
IF the locks cycle twice it has failed.
The most common reason for programming failure is because the car didn’t receive a good signal from the remote. To fix this problem try these tips. 1) Stand outside of the car while you are performing steps 8 and 9. 2) Don’t hold the remote buttons down as long.
As long as the car is still in programming mode you can keep trying steps 8 and 9 until you complete the programming. If you wait too long and the car exits the programming mode then you must start over.
After you get the remote to program then continue on with step 10.
10. Close and open door to end programming procedure.
FAILED!
... I did the follow steps in post #3 and it failed. I found out that you cannot re-programming a used key from another car (same model tho). It is useless to buy a used key fob. For it to work, the immobilizer must be reset and all the keys have to be reprogrammed with a new code to work. So I decided to buy unprogrammed key fob, it costly but hopefully that will work.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Help... For some reason, I can't get pass the Key Programming in step 4.
Everytime I pull out the master key, the security light comes back on.
There is a limit to how many keys can be programmed to the car. I believe the magic number is 4. When I originally bought my car it only had 1 master key, so first thing I did was have a spare made. I found out that there were already 4 keys programmed to my car, so in order to program my new key I had to erase all of the keys and reprogram my original and add my new keys. This might be the same problem you're having. I wish I could tell you how to get around it, but I have no idea.
