WIll the Treadstone is300 cast turbo manifold fit a pre late 97 head?
Ok so i am starting to part my turbo kit together and Reid at sound performance has sold me on a cast manifold after he took me for a ride in a supra with a Treadstone cast manifold on it. That manifold plus a sound performance quick spool valve and a Percision 62 65 billet turbo. So I just bought that turbo and the spool valve now i need a manifold. SO is the vvti head have the same exhaust studs as the non vvti head? And if so do you think the manifold will clear the distributor?
Here is the link for what im talking about.
http://www.treadstoneperformance.com...C+Supra+2JZ-GE
I tried to find more info on this manifold and installation but there is none at all, and no user experience anywhere. I was going to do the the QSV and 35mm adapter to 44mm tial vband wastegate. From what it looks like there should be plenty of room for the QSV and to clear the stock dizzy since it mounted the compressor cover lower than most manifolds.
[QUOTE=HiPSI;6486411]I tried to find more info on this manifold and installation but there is none at all, and no user experience anywhere. I was going to do the the QSV and 35mm adapter to 44mm tial vband wastegate. From what it looks like there should be plenty of room for the QSV and to clear the stock dizzy since it mounted the compressor cover lower than most manifolds.[/QUOTE
Yea im sure with the spool valve it will push the turbo down and over enough to clear the dizzy... i hope if not i guess ill just have sp make me the first NA F1 manifold lol
well i think im just going to buy it and look at it i emailed the guys at treadstone and they said it would fit and if it didnt i could return it so. And as for the spracing manifold is it a divided manifold?
