so I went drag racing.
Went drag racing at Brainerd International Raceway today.
I hit 13.2 @111mph with a 60' time of 2.4
Im running 22 psi and make 471rwhp and 425tq on my 1jz single turbo with no LSD.
I ran that time on 255 street tires on my 19's.
Im wondering if this is about the right time or should I be faster?
11'S is honestly out of the question unless everything is perfect and by that you need at least a mid 1.4 60ft which you need slicks and a more aggressive rear end gear ratio as thesee cars are lazy out of the hole so to re cap you would need slicks,better gearing,lsd or welded diff and maybe n20 but I could see high 1.6 60fts on just slicks and a good launch that dead hooks.
Are you auto or 5spd?
I'd say the trap speed is low for that kind of HP. It's the indicator of power; ET shows how well you put it down. You should be at least 6-7 mph faster on the top end.
Also keep in mind that when you increase traction, the next weakest link in the chain is what breaks next.
