SC- 1st Gen (1992-2000)
Battery drain
Old 06-27-11, 01:58 PM
BigBang
BigBang's Avatar
Default Battery drain
The battery was replaced brand new but after a day it was completely dead. Something is draining the battery's power. What could be the problem?
Old 06-27-11, 02:21 PM
bleedspeed
bleedspeed's Avatar
did you install an aftermarket stereo? something big would have to be on to drain a new battery in 1 day. maybe your amps? or you could have something grounding out in the charging system and shorting the battery in which case the battery may be dead. or you could be not charging have you had the alternator checked out? otherwise it could be any little electrical failure.
Old 06-27-11, 02:59 PM
scENFORCER
scENFORCER's Avatar
^ +1 on all that was said above. Was gonna say the exact same thing, either some sort of aftermarket stereo/amps, or alternator.
Old 06-27-11, 03:07 PM
88supramki
88supramki's Avatar
check your alternator first. stereo would accelerate the process if the alternator was dying or dead
Old 06-27-11, 06:31 PM
BigBang
BigBang's Avatar
It's not an aftermarket problem since it's completely stock. I'll check that out, thanks.
E36M3
05-18-15 10:18 PM
sam600rr
Performance & Maintenance
01-23-12 06:37 AM
scENFORCER
15
07-07-11 03:17 PM
2ya
08-02-06 04:50 PM
SLVRGS
GS - 1st Gen (1993-1997)
02-03-04 11:54 AM
Quick Reply: Battery drain
