Headlight Woes
So I have a '2k sc300 and have always been disappointed with the lighting. There is no yellowing on the covers and Ive tried both PIAA replacement bulbs and HID, but the lighting is still dimmer than most cars on the road. My multimeter reads 13.4v at the low beam connector on both sides, so what gives? My adjustments are based on the level and left/right adjusters and both are at "0". Can both lens be that bad? Any input is appreciated..
TIA
TIA
ur glass projection ball inside ur headlight is probably dirty... look for a DIY by a member named O.L.T. and try that
edit here ya go found it for u...
https://www.clublexus.com/forums/sc-...finishing.html
Yes, you have to align the bulbs properly in the housing or else they will look all lop sided. If HID were not bright enough for you and they were in there properly you're screwed and/or blind.
