Street turbos- lets see some nasty dynos!
Hands down the 2JZGTE is probably the greastest stock engine ever built! I want to see the nastiest street dyno charts and turbo set-ups! who has the most torque at the lowest rpm? who has a broad power band that goes from 3200 to 7500 RPM? I am building a daily driven street SC300 and i want some tips and advice on how to get some low RPM torque and power. If I have seen a nissan KA34DE make 375 FTLBs at 3500 RPM, I want to see a 2JZGTE do the same, but i havent seen many dyno charts that have these kinds of numbers. my ultimate opinion for a street set-up (other than cost) is a 3.4 stroker, mated with a T67 turbo. Or since Sound Performance swears by it, an SP Spool valve with a Garrett GTx3582R turbo. if these valves work please, let me know lol.
I am doing this exact build soon with an na-t and cant wait. But as far as the quick spool valve no after riding in that car and seeing how diff it feels with the valve open and when its working like it should is amazing. The power comes on so much faster and you have a way bigger rev band. And yes it would help spool a big turbo faster but it works great on smaller turbos as well.
You can get plenty of usable, daily-driver type power by simply using a more sanely-sized turbo. My brother's Supra had an SP57 and it wasn't setting dyno records (~505 whp at 19 psi on pump) but all of its power was available at normal rpms. It trapped over 120 mph so it was no slouch up top either. Versus other Supras with 200+ more whp, the big power cars had no chance at the punch; they took several seconds to get into power and finally start gaining against the small turbo car. That's an eternity when the other guy is at WOT and you're waiting.
I guess it all depends on if you want to drive it and enjoy or to use it to impress other people. The sky's the limit on max power but you can always think a little smaller for something that's blast to drive and easy to keep in a straight line when boost comes on.
http://www.youtube.com/watch?v=cNYdVGrOcH0
enjoy, spools pretty fast and works very well for what I need.
my engine specs.
https://www.clublexus.com/forums/per...ld-thread.html
Video was on low boost so do the math on high boost 28psi
my engine specs.
