passenger door handle issues
My passenger door handle outside handle is loose. When u open the door from outside the left side of handle comes out. Anyone have a fix? I searched but no luck on this. Maybe a diagram so I can find the bolts or whatever is broke.
I had the rearmost door handle bolt fall out .... I put in a bolt that was about 1/8" longer with red threadlocker and its holding ... Its a very hard bolt to access.. U have to reach thru a hole in the door before accesing the bolt ... I used a telescopic magnet attached to the bolt head, slid it through, then hand tightened.. Then used a socket.. Do not strip the bolt.
So our theory is that there was some extra thread deeper on the female side that wasnt stripped... I am not positive that the bolt that fell out of mine was the original..
Good luck.. If that doesnt work i think u have to remove the window to get the assembly out to fix..
