help with 1st gear on auto tranny issue
I always had an issue with my auto trans on my sc300, because it takes forever to shift from 1st to 2nd gear even, if I step on the throttle all the way. It shifts ok on all the gears but 1st gear. It feels really slugish on 1st. I actually have to put it on ¨L¨ if I want to speed up the process.
I was told it can be a sensor that is inside of the trans. It has been doing it for months..
Has anyone had any similar issues ? or have any idea what can that be ?
ok sorry to say but ur tranny is slipping due to the 1st gear clutch pack worn out. to shift try letting off the throttle all the way and putting it in agina
I actually have a r154 swap I just need to extend the shifter and buy a speed sensor. I was just trying to keep the auto untill I gather up evrything and installed. It looks like I have to do the 5 speed swap sooner that I thought.
the trans shifts great but 1st gear. what I will do next is replace the filter and, see if it helps out a bit.
