springs
i have them... it says it on there site. 1.2f/0.9r
im on 20's so it looks high... if u go with smaller wheels i recommend u get different springs because its an unnoticeable drop
^^ yea i know u would be... Thanks a lot! i know its not the taste of many but im not going for the same look as other ppl. here is a pic of the car stock with the springs (no rims) not that much of a drop. Dont know what ur into but if ur into LOW than they r not the way to go. good luck
Actually that's^^^ the perfect height for me. Did you change the shocks as well? I'm looking to get a drop but not to much of an aggressive drop due to the streets here in NY and I hear the nf210 springs aren't that comfortable on ride quality.
Depends on what size tires you run. The wheel diameter is not going to dictate the overall diameter, the tire size and aspect ratio will.
A popular set-up on 18's is usually a staggered set-up in 8.5 - 9.0 and 9.5 - 10. Tires in the sizes of 245/40 and 275/35 will maintain the factory O/D.
