SC- 1st Gen (1992-2000)
swap compatability questions(iam not a noob)
Old 07-23-11 | 12:50 AM
megamax's Avatar
megamax
Default swap compatability questions(iam not a noob)
alright fellow sc owners a few things.
-can i use the flywheel bolts from the 1JZ automatic flexplate bolts for a flywheel foe my w58??
-if not i also pulled the flexplate bolts from my n/a ge block. would these also work??(remember iam dong a 5spd w58 swap).
-also will my gr rear sump oil pan bolt up to this 1jz block without a problem or modifications??(its from a chaser)
-and finally. When it comes to oil pan gasket maker. i have some nissan oil pan stuff left over from when i did my rb last year. so wondering if it's oem and it works on the nissan, then it should work for the sc correct??
Old 07-23-11 | 01:02 AM
88supramki's Avatar
88supramki
Not sure about the flex plate question. But yes you can use your GE pan. Just remember to drill & tap the spot for the oil return line
Old 07-23-11 | 08:45 AM
megamax's Avatar
megamax
drill and tap?? please more info on this??
Old 07-23-11 | 09:14 AM
goohead's Avatar
goohead
its not on that oil pan so you have to make your own
Old 07-23-11 | 10:22 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I believe he was prolly wanting someone to tell him how?
Old 07-23-11 | 11:28 AM
spoolxexo's Avatar
spoolxexo
Yes it is.
There is a spot in the casting to drill and tap holes.
http://www.youtube.com/watch?v=GUn3j...&feature=inbox
There ya go.
Old 07-23-11 | 12:21 PM
adl16v's Avatar
adl16v
u cant use flexplate bolts for a flywheel they are different length. Flexplate is much thinner then a flywheel
Old 07-23-11 | 01:15 PM
megamax's Avatar
megamax
thank you on and i forgot to add what about the bell housing bolts??
the auto appears to have a few more but a Majority seem to slide in the w58 and they look like they will work..
Old 07-23-11 | 01:29 PM
megamax's Avatar
megamax
Originally Posted by spoolxexo
Yes it is.
There ya go.
thank you for your assistance??
Old 07-24-11 | 03:02 PM
megamax's Avatar
megamax
bump for an answer!!!
tuterz
01-09-16 02:47 PM
mrcoqui
Performance & Maintenance
04-02-13 01:10 PM
19ES250
09-04-11 03:38 AM
Lowskee
03-24-11 04:22 PM
SC2JZ300
07-30-09 11:19 PM
