TUNE my 1jzgte!!!
No you should be ok but it's nice to have a back up ecu .. All the CAPS and drivers were tested on the board of the ecu as well as thoroughly cleaned. You can pick up the auto soarer ECu from someone on this forum for like 100 bucks .
ry removing the safc or make sure the type is set to 'pressure' since it has a MAP. you cant just remove the afc by just unplugging since it is wired to your MAP you would have to re-connect the MAP wires in the main harness
StuntKing
Performance & Maintenance
13
12-13-12 10:03 PM
kaotiq
07-23-04 06:39 AM
