SC- 1st Gen (1992-2000)
Diff/HalfShaft/Can someone tell me what it's called please?
Old 07-27-11, 02:07 PM
antonio356
antonio356's Avatar
Default Diff/HalfShaft/Can someone tell me what it's called please?
Can someone tell me what the part is on the end of the diff please?... It's the section where the axle connects to on the diff. Also can someone point me in the direction where I can find them?
Old 07-27-11, 02:15 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
The picture showing is where the axle joins the rear end. Do you need a rear end or a axle or the plate that joins the two?
Old 07-27-11, 02:53 PM
xspsi6
xspsi6's Avatar
It's generally called a tulip and finding one can be hard but a diff can be had for 50-75.00.
Old 07-27-11, 02:57 PM
antonio356
antonio356's Avatar
Thanks guys... Might need the part that the axles connects to.. If you remove it from the differential it has a spline inside of it... It may seem as though I might need to sources a pump... Reason being when I accelerate my car pulls to the right side... Took a shop and they said it was the control arm bushings but I'm questioning that as the pull that I get is only from acceleration. I can lift of and it settles...
mk4r34
Performance & Maintenance
09-13-12 09:12 AM
Sc3001jzTT
07-29-10 04:35 PM
Slow_go_400
04-30-07 10:56 AM
bpc23
11-17-06 09:17 AM
Quick Reply: Diff/HalfShaft/Can someone tell me what it's called please?
