a/c for sc300 92
Does any one know how to reset the shut off switch in the condenser. The a/c light blinks after 4 to 6 seconds and then the condenser shuts of. I have to keep switching the a/c on. It cools when the light is not blinking hence the condenser and freon if working.
I am having the same problem right now. I believe that my compressor clutch is slipping so later on today or tomorrow I will be taking it off and trying to adjust the shim. when I start the car with the A/C on I can hear the clutch slipping but then it grabs and cools fine. If I drive slow and dont get to high in the revs it works just fine the majority of the time. However when revs go above 4000 it cuts off again and the little light just flashes. Apparently our cars have an RPM sensor on the Compressor the ecu reads this and the tach signal and shuts the a/c off if they are not spinning at the same speed. Hopefully a thinner shim will tighten this up and solve my problem. Im keeping my fingers crossed because it is just too hot in Georgia to not have A/C.
