Mystery Fog fuse
When I had my 96 foglights one them stopped working due to water getting in the light. Now that I have 97 fogs, i went to look for the fuse for the fogs. When I saw the fuse location diagram to see where the fogs were there was no slot for them where theyre supposed to be
.I'm at a loss here. If there's no slot for it then how am i suppose check/replace the fuse? Thanks for any suggestions you come up with.
Same exact thing happened to me. The fuse is in your kick panel, its not in the box where the rest of the fuses are, idk why. If you have a light or long fingers, lets say your starting off at the bottom of the fuse box in your kick panel, you wanna keep going all the way up, pass the box by about 4 inches, and its to your right, theres 2 blue 15 fuses. Its the one closest to you. Hope that helps.
![](https://farm7.static.flickr.com/6005/5988970052_9813541575_b.jpg)
boostedg
04-11-14 12:10 PM
