Transmission problem??
Hey CL Fam... I just recently replaced my master clutch cylinder and slave cylinder on my SC300's W58....I installed it into my car and everything was working fine and shifted smoothly with no problems. Then 3 days later while driving to school, It began to lose pressure and now I cant put it into gear when the car is on. When I push down on the clutch pedal, it isn't as stiff as when i first installed the new master and slave cylinder. I would also have to bring the clutch pedal back up manually because it wouldn't come back up all the way on its own. I tried bleeding it several times and still the same issue. I had replaced the clutch slave cylinder again with a new one and still low pressure and wont go into gear. I tried using my old master and slave cylinders and still the same issue. I never abused this car and it has never given me any problems until now. Any advice from the Gurus would help so much!! Here's my beast.LOL
![](http://i955.photobucket.com/albums/ae35/Mrvichai/IMG_0389.jpg)
baodalazi
Performance & Maintenance
10-17-11 10:47 PM
baodalazi
SC- 1st Gen (1992-2000)
03-21-11 10:54 AM
