SC400 Automatic transmission change?
I recently was pasted down a 1992 Lexus SC400. I am approaching the 30,000 mile marker, and I want to change the automatic transmission fluid. I jacked up the car and found the drain, but now the question for me is, "Where do I add the new transmission fluid?" I looked at the engine compartment and noticed the dip stick where you check the level of the transmission fluid, but I am more than certain that is not where you add the new fluid. Also, how many quarts of oil would be needed, if I drained the oil from the drain, on the bottom of the vehicle? If any one can help me out, I would appreciate it.
schmoozer
01-11-14 01:07 PM
trancez
Performance & Maintenance
10-15-08 07:47 PM
dumdumgreg
06-20-02 02:16 PM
1993, 1994, 1995, add, automatic, change, check, fluid, interval, lexus, replacement, sc400, trans, transmisoon, transmission
