SC300 wiring
SC300 wiring
i bought a theft recovered sc300 for really cheap, i got basically everything for the car already, seats, radio, speedo, climate control, everything! the only messed up part was that all the wiring on the center console was cut, i got all the wiring, put them together color by color, everything works EXCEPT the climate control. i double and triple checked the wiring, i checked the fuses, still nothing. i know the climate control works cause it was working on a running car. its not like i'm mechanically inclined or electrically stupid. (except in this case) anyways i'm wondering if anyone has a diagram for the climate control. or has any suggestions. thanks in advance
I'm not sure if this will be much help to you but I'll try. When I installed my remote starter everything went fine except I realized that the time would ALWAYS stay on even w ith the car off and it really bugged me so I got it so the time wont always stay on but the other problem was the alarm would go off if I tried to start the car if the sercuirty light was on. If it was off the car would start and everything seemed fine. The only problem was the AC wouldnt work. the back light would work but couldnt see the stuff on it or turn it on or anything. I realized why. When the car was on the accressory wire was not turned on with it. If you dont the the acc. wire I think its also called the blower motor or something wire the AC doesnt function without the key being in the on position. You may want to check your acc. wires. I think that would cause that problem. The car will function fine but the AC wont work. If I rememeber right the acc. wire is a red and white wire or a yellow and black wire. I lost the sheet I had all that stuff on but its under the dash by the brake. You might want to double check that. Sorry if this was no help but its a start.
Davidddd
SC- 1st Gen (1992-2000)
08-25-13 07:18 PM
nkenyon44
02-19-12 11:41 PM
2JZGTE SC
12
02-11-09 12:27 PM
