need thoughts about engine swap
well i just got a sc300 bone stock and i have an offer on a sc400 motor. what should i do? should i get the motor? what else do i need to do for the swap? any good modifications i can do with the sc400 motor? what are the pros and cons about this? all that is missing is the water pump though. i need some help on this!
Don't get the motor... you should search before you post. 400 has little aftermarket support and it is expensive to modify. If you like the 1uz then buy an sc400. keep your stock motor and go na-t or swap it with a 1j or 2j. There is no point in putting in a v8 in your 300.
Indeed, if you want a V8.. of weel , just trade it for a sc400. As some other members stated a 2jzge Na-t will be your best bet. If you add a turbo to the equation I am, sure you will be making 340 hp with just a turbo kit and some tunning.
dont waste your time my friend 1uz = lots of money to modify, but thats if your actually planning to mod your car, otherwise keep what you got the 2jzge to 1uz is not worth the time, money, or headache or like everyone else said trade it for a 400 if you really want the v8
im a 1uz guy but im still with everyone here.
The swap is going to be a pain and the 1uz is hard to modify after its in.
The only benefite to going 1uz is they are extremely cheap to buy , ebay has them for around $500 with very low mileage(30-40 000miles)
We need more info, do you know how to swap the engine yourself or are u paying someone else?
How many miles on your 2jz also .
DO NOT buy this motor. Complete waste of money. Doing the swap might cost you almost what you paid for the car and is not worth it. Sell the 300 and buy a 98-00 SC400 if you want a 400 so bad. Otherwise the 300 is better cause than you could turbo it easily.
