92 Sc400 Transmission
I just bought my 92 SC400. My friend's mom didn't change the transmission fluid while she had it (3 months). It's pretty dark, I'm dropping the pan and changing the filter tomorrow. I'm only draining the 2-3 quarts that leaks out when you do that and then putting the pan back on because it's been strongly recommended to me that older model SC400s especially with high mileage (205K) and neglected transmission fluid should be gradually introduced to the new fluid, so I'm just going to change the filter and 2-3 quarts with every oil change for a while from now on. Neither of us knew the owner previous to us, the car was bought at an auction. We don't know what kind of transmission fluid that was used last time. I know that mixing types is really bad. Blah. I'm just going to add a few quarts of the good old Toyota T-IV from the dealership. Everything should be okay. I wont forget to clean the magnet either. Should pop or screw right off. Thoughts, concerns, and wishes of luck are appreciated.
No, No, No. When you do an oil change do you only drain out half the oil? Well that's what will happen if you don't flush the fluid still inside the transmission. As the fluid ages it picks up metal particles from regular wear. Some get trapped in the filter and the magnets but some does not. Well those particles turn the fluid abrasive. Not removing all the fluid is a very bad idea because those particles will remain.
A nice guide for you.
http://home.centurytel.net/stevenjac...sh/tranny.html
Yes, I would do it the way you're doing it. I would not flush fluid in an older vehicle with unknown maintenance history. My Sc's fluid had been neglected and started skipping gears randomly. It made a huge difference changing the old fluid. The car shifts like new. Just make sure you clean the pan/magnets out really good.
Yes, I will clean the magnets well, using a scouring pad on the pan itself worked well on the residue, but I spent many paranoid hours rinsing and wiping it as small metal particles of the scouring pad inevitably fell off. I slid the magnets across the pan periodically as a way to check for unseen leftovers and religiously rinsed the dipstick tunnel.
I will most certainly post the results immediately on this same thread. I strongly anticipate a dramatic increase in performance but will report back with honesty. If the performance doesn't noticeably increase I'll assume the solenoids need to be replaced. We shall see soon enough, most likely this Friday.
I don't know what kind of stuff you learned on the Focus Forums but changing out the fluid doesn't provide you any performance gains. It's about prolonging transmission life. Possibly smoother sifting but that's about it.
Transmission fluid is good for 60-90k miles, I have no idea who would recommend this 10,000 change, possibly the same person that recommends leaving half the bad fluid inside?
I already positively referred to your original post on this thread and complimented it's accuracy. However there is no harm in changing my transmission fluid every 10,000 miles. And I already stated that the reason I am only changing half for now is because it's all I can afford, I must use my vehicle in the mean time, and I'll be doing a proper full change in three weeks.
Please read my post referring to your post to reassure yourself that we actually don't disagree with each other.
lionj
Performance & Maintenance
16
11-10-07 06:29 PM
mwwfla
02-09-07 05:53 PM
400, change, conditioner, filter, fluid, learn, lexus, pan, replacement, sc, sc400, shift, toyota, transmission, unlock
