SC- 1st Gen (1992-2000)
Fix stock engine or get a reconstructed one?
Old 08-09-11, 08:21 AM
SC300P
SC300P's Avatar
Default Fix stock engine or get a reconstructed one?
Hi guys ang girls,
I need your opinions. I bought my SC this April with over 230,000 miles on it. Now it has about 245,000 miles. A mechanic that I took it to told me the valve springs and the "screws" are worn out and needed fixing. It would cost me $300 for labor plus parts ($100-$300).
Should I repair that problem or should I just replace it with a reconstructed enigne? WHAT DO YOU THINK?
Old 08-09-11, 09:32 AM
TLDriver
TLDriver's Avatar
valve springs and screws?? are sure that's what he said?
Old 08-09-11, 09:55 AM
BigBang
BigBang's Avatar
Well assuming you don't know how to do the labor yourself if you bought a reconstructed engine, It will probably cost more to do the swap. Then again it does have a lot of miles. It's really your choice. In my opinion I would swap it. Swap it for a 1j or 2j. Then you will have more reliability.
I think he meant valve springs and probably the stem seals. The valves itself might need to be lapped anyways.
Old 08-09-11, 10:02 AM
1WILLY1
1WILLY1's Avatar
when u buy a car with high mileage u are eventually going to face this choice.
I think its a bad idea to keep throwing money into a high mileage engine
Old 08-09-11, 10:22 AM
soarer93
soarer93's Avatar
id say spend the few hundred. get it fixed. then look at selling the car. dont butcher it up by doing a swap.
Old 08-09-11, 10:42 AM
BigBang
BigBang's Avatar
I'd feel like a loser if i just bought a car that I have to try to sell if it sells.
Old 08-09-11, 02:24 PM
Tabaka
Tabaka's Avatar
Man, that's a good price. Just got to keep in mind that motor will reach 300k in a few years. It's up to you really. I had to make that decision recently and kept my GE. I only had 130k though and is running great now. Can you confirm the last time you had a timing belt/waterpump service?
Old 08-09-11, 02:30 PM
BigBang
BigBang's Avatar
130k is still really good mileage. Most people avoid buying cars over 100k... which is sad
Old 08-09-11, 07:56 PM
Klaus
Klaus's Avatar
My 260k mile SC4 runs perfect
Old 08-09-11, 08:01 PM
BigBang
BigBang's Avatar
186k miles before engine died here. Previous owner prob didn't take care of it that well.
Old 08-09-11, 10:00 PM
SC300_704
SC300_704's Avatar
here we go again about the mileage lol.
Old 08-10-11, 06:34 AM
Tabaka
Tabaka's Avatar
truth, that's cause everyone looks up to you Gives us NA-T people hope that it's never too late!
Old 08-13-11, 02:57 PM
SC300P
SC300P's Avatar
The guy who sold me the sc didn't take care of it. He used cheap oils and had a dirty air filter. He also had some huge 20'' rims that rubbed against the inside walls of the fender. Let's just say he's a flashy guy who's into looks rather than performance.
As I could, I did an oil change (put in Mobil 1 high mileage 10w-30), put a clean Mobil 1 oil filter, changed the air filter and also added the Redline SI-1 fuel system cleaner. Now the engine sounds a lot better. Next step is instal new brakes, new spark plugs, change the valve cover gaskets and get stock rims.
Don't know if the previous owner changed timing belt or water pump. My sc was neglected.
chiefnomad
01-27-16 06:23 AM
Dj_AmtraX
12-15-10 11:15 AM
350PsDMeuP
02-16-10 07:00 PM
Frankdorn
02-08-10 07:51 AM
VQT
05-30-02 08:43 AM
Quick Reply: Fix stock engine or get a reconstructed one?
