SC- 1st Gen (1992-2000)
How much should I expect to pay for a gte getrag swap?
Old 08-12-11, 09:33 AM
88supramki
88supramki's Avatar
Oil pump, is it VVT-i or Non VVT-i? If you're going to do it "right" the first time then break it down and do all of the gaskets and seals as well. If you do the timing belt, you might as well do the front main seal.
http://store.driftmotion.com/static/...egasketset.php - There are other places that you may find cheaper, this is just one option
http://store.driftmotion.com/static/...onpedalset.php - full pedal set
Don't forget you will need a new driveshaft as well, the SC one won't mate up the v160
Old 08-13-11, 09:44 AM
AlphaMotor
AlphaMotor's Avatar
Wow thanks 88supramki! Just in case I can't find a used pedal set on CL this will be my backup plan!
Mr209sc300
02-07-11 10:13 PM
313sc3
Performance & Maintenance
01-08-05 01:35 PM
JohnGS4
Performance
12
05-23-04 09:04 AM
DriftGirl
04-25-02 04:41 PM
Quick Reply: How much should I expect to pay for a gte getrag swap?
