94 sc400 steering wheel
I have recently purchased a 94 sc400, the steering wheel is in real bad shape. I have found a wrecked 94 at a junk yard that i am getting some trim parts off of. Unfortunatly the steering wheel is bad too, but there is a early 90's es300 with a nice looking wheel they look identical but are they interchangeble? If so how hard is it to remove the steering wheel?
1JZ Single SC400
Not hard at all. Just remove the torx bolts.from the back remove the airbag. Then the center 17 or 19mm bolt. Prolly need a steering wheel puller might not? Ask for assistance if needed. They might have one you can use. Make sure the steering wheel is a stage 1 airbag.
The 90's es300 wheel will fit and the links on how to remove steering wheel.
https://www.clublexus.com/forums/es3...g-wheel-2.html
http://planetsoarer.com/leather/remove/index.htm
