Slammed my car. but 1 small problem...
After recently slamming my car....i could barely fit my face under it to inspect the suspension, but when i did....i noticed that the rear sway bar link is making direct contact with the LCA....like literally bending on it. wtf?
Anybody else experience this on their slammed SC
either the car is to low which is probly not it...something is bent sway bar, LCA, or the whole sway is off alignment due to bad sway bar links....how does the other side look?
trust, the car is slammed. 19's are tucking.
sway bar not bent, LCA's not bent either. the sway bar links are definitely rusted/rotton, but that doesn't explain why they are touching lca's.
the links are bending on top the lca's, on both sides of the car.
Jack up both sides of the car to relieve the tension on the sway bar if that's not enough, then unbolt the endlinks and re position the sway/endlinks
