Lowered on nf210's & seems high in front w/ pics
#31
that part didn't look like opinion, it looked like bad information. That's all he's trying to clarify, and you're getting butthurt.
OP: maybe check to make sure the rubber isolator on the spring perches is set correctly, with the little bit of driving you've done, it may not have been noticeable. I will say my stock-height looks like it has less gap (or equal gap, at the most) to your current setup.
#35
Im sorry, but why would you every waste money on springs and struts? Just buy coilovers, there are multiple sets now that are only 100$ or so more then the strut and spring set ups and you get FULL ADJUSTABLE CONTROL. Springs and struts seems like a very foolish invest to me
I totally agree with this. Why spend $100 on shocks and springs when $200 will get you adjustability in both height and dampening? (the price was just made up to provide an example) I never understood this.
#37
#40
Food for thought. I'd rather run a reliable $650 Tokico HP/Tanabe combo for the time being, rather than an $800 coilover package that will probably have a leak or noisey tops within 5k miles. Most of the quality coilovers I've seen/experienced are $1k + (Stance, HKS, etc).
It'll be a never ending battle with everyones different wheel/tire combos and how their car sits.
#41
regardless of how you said it, what I (as many others, apparently) read is "20's will reduce wheel gap, otherwise you need to go lower"
op: i apologize if my opinion was miss leading... to clarify, rather then getting small wheels with big tires to fill the gap, i would(actually i did) get 20 inch rims with watever size tire will fill the gap. just so u know, my car drives fantastic. otherwise i think ur car looks very clean at that heighht even with those wheels. i would trade u both my sc' for urs... lol
#43
whats ur wheel specs.. im loving it.
#44
As to the cutting 1 of the dead coils off the top, That is something I thought of and imo it should be fine as it's a dead coil and not anything more so I may try this as a last resort and I have heard of people putting supra lowering springs on the front as it is supposed to be a direct fit however the rears are different spring pearches.
#45
