Flip out keys?
Has anyone used one of these: http://cgi.ebay.com/ebaymotors/UPGRA...item2566d6eadd.
Any problems with the SC? There is a shorter one as well, but I'm not sure if this one has problems with the transponder being too far away.
(Have a 99 sc300)
(Have a 99 sc300)
Apparently they will, it might be a special circumstances case though.
https://www.clublexus.com/forums/gs-...lip-style.html
apparently this seller will cut for you.
http://cgi.ebay.com/ebaymotors/UPGRA...item2313761d1f
second style as well. I just emailed them to order. Will report if it works.
I tried ordering the same key for my 99 sc300 and they told me it wont work. This is what they told me
" Unfortunately, our listing as you probably know is new, and in attempting to process your order we discovered that our swithblade shell keys will not work on 1st generation Lexus vehicles which use what is called a "long or eight cut" blade. The shell/key needed for your vehicle only comes in the standard 3 button type. We will gladly refund your order if you like or you can converted it to a standard type and we will then refund you the difference."
I just bought the old style key and it works good. I sent them pictures of my key blade and they cut it for me
