Just Hit 200k
I just bought one too with 226,000 miles on it timing belt and water pump was changed at 175,000, it was a mechanic who owned it before me and it was well taken care of but I want to get it checked out anyways. So far its been running really quiet beside some squeak coming from the middle console somewhere. Anyone have any ideas how much it is to check eveything that was listed?
Timing belt/components
Ignition components
Fuel components
Fluids
Oil/filter
transmission fluid/filter
Differention fluid
power steering fluid
break fluid
coolant
fuel filter
Air filter
A/C...new compressor it sounds like/ if you havent already tryied a recharge?
prolly need to look at your suspension too, bushings,control arms etc
timing belt, water pump, wires, plugs, distributor, O ring, every gasket including valve covers,
Ignition components
Fuel components
Fluids
Oil/filter
Differention fluid
break fluid
coolant
fuel filter
Air filter
I took my SC to the shop today to see what was wrong with the a/c. I was hoping it just needed to be recharged with some freon, but it was worse. Turns out the Compressor has seized, therefor it is time to replace it. Does any body know where the best affordable place to order a compressor from?
Scroll down to the classifieds section on Club Lexus. Create a thread that reads: WTB AC Compressor ASAP
and your PM inbox will be filling up in no time. You'll probably get one for $100 give or take. Add shipping, you're looking at a week tops. Best of luck man.
