Ca. i faild smog any ideas hc to high
so i failed smog
my hydro carbons are to high i got 119 min to pass is 70
before smog i put in gauranteed pass smog fuel injector cleaner
fresh oil change,air filter
i have no engine mods except fireball megas which wouldnt do anything really
my friend told me its my cats
im gona try the guaranteed pass stuff one more time
change fuel filter
and seafoam thru booster
and other things i should try which arent so cost effective
its funny i think i pissed off the test guy cuz my car is so damm low and i have a welded diff hes scratching his head like wtf...
change fuel filter
Have a scanner hooked up to your car and check the o2 sensor readings. High HC normally indicates incomplete combustion of the fuel. Make sure the sensors are reading correctly, otherwise your car will default to running rich. Check the basics like air filter and spark plugs.Not having enough air or spark will not allow a complete burn of the mixture.There are quite a few things that can be associated with high HC..
Changing fuel filter won't do anything so I'd skip on that.
Oconee1985
Performance & Maintenance
04-26-13 05:44 PM
