SC300 Accelerator Pedal Vibrates?
Got a 99 sc300 recently, working through some kinks.
One I can't put my finger on is that the accelerator pedal seems to vibrate when I push it down. Usually in lower gears, not as noticeable on the freeway.
Any ideas? I had my mechanic check out the transmission and engine mounts, those were fine.
I have the same problem too, I changed the engine/tranny mounts as well, and it is not the problem. I think it has something to do with the throttle cable. If you figured it out, let us know!
jacobsc300
Performance & Maintenance
06-03-15 02:12 PM
Ariyanna
07-06-08 05:26 PM
