Had to tow the SC400 yesterday...few questions
No fuel smell when cranking it starts right up, actually even better after replacing the battery. The fuel smell is consistent when it's at idle. The CEL and the O/D are blinking consistently so that means no codes for either. If the cats were shot wouldn't it through an 02 Sensor code or something of the sort?
the cats could maybe be the culprit.
You can buy a infared temperature reader and check the temps of the cats, see if one of them is overheating, thats how the mechanics do it.
Then you can just return the temp reader to the store when your done, wont cost u a thing to diagnose
Not a bad idea thanks *****
what about the crazy rattling covering from the cat? that goes away when i rev it and hold it at about 2-3grand and comes back at idle.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Nope not hesitant at all just haven't had enough time to do research on the car yet before something broke. I'm sure I can search for info
Is there a DIY out there for ignition coil replacement? Not having much luck in my search...
hey sorry ive been away the last few days or so.
Guys correct me if im wrong but there is only two coils on the 400. the left and right and they both control 4 cylinders each.
There is no way his coil is bad because he would know if his car is only running on four cylinders.
It happened to me last christmas and there is no way u cant notice, your car will shake so violently u will think your engine is about to blow up literally, and will hardly reach 2000 rpm's.
it might be possible one or more of your wires or plugs is reaching the end of its life and it might be a good time to do a tune up.
Even if your wrong and its something else at least your car is tuned up , something u should so every so often anyways so your not really out any money.
if there is any new info please let us know, did u manage to check the cats at all?
Sounds like one of your ignition coils is out. IF so your cats would heat up and most likely makeing that sound and smell, running on 4 cylinders with no spark, fuel, wasting gas, etc. Check your coils.
